ok, here's the skinny... rideing my 98 bayou 300, its like 2am, and having lots of fun.. Thin... OHH SH**... tree... the bayou climbed it like a monkey, my head lights wher pointed at the sky. i checked it over and no damage. so i parked it for the night. 2 days later i take it out for a ride and its overly loud and and losing power when i hit the gas. i checked the exhaust and no visible damage. i checked everything i can think of and still the same:aargh: can any one help?
I would check to see if the frame is out of alignment if you have not already.
Secondly I would check and see if your intake and air filter are in place and working properly.
Did you feel a jolt when you hit or was it low speed?
Is it loud like exhaust noise? Put a rag over the exhaust and see where it's leaking if it is, watch out cause it's be hot. My guess is the manifold is cracked or gasket popped out,or a problem with the exhaust pipe, if it's an exhaust noise.
* Added full year and issue to thread title.
thanks guys! it was the head pipe. gess when i ran up the tree a stick punched a hole in the head pipe and broke off inside. so i ordered a new one and it sound's fine now, and no power loss. ;)
thanks guys! it was the head pipe.6b37fa60.gif guess when i ran up the tree a stick punched a hole in the head pipe and broke off inside. so i ordered a new one and it sound's fine now, and no power loss. ;)
  • 10 years later...
Bonjours je sait pas si quelqun a une réponse a ma question jai un kawasaki bayou 300 4x4 il démarre mais na pas de power et fait de la boucanne blanche et je ne sait plus quoi essayer si quelqu’un a une réponse serait très apprécier
    • By Kawasakibayounospark
    • By neilroy87
    • By beast6228
      However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it.  If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
