ProMark is selling their 1500 lb XT winch for $89.99!
ProMark 1500 lb XT Series ATV Winch. Save 50% Off Retail.
1500 lb XT Series ATV Winch with Accessories
  • Limited Lifetime Warranty
  • Standard Accessory Package:
  • Handlebar Thumb Switch
  • Roller Fairlead
  • Winch Hook and Pull Strap
  • Sealed Quick-Connect Contactor
  • Thumb Toggle Free Spool
* Fairlead Mount Not Included. (A Universal Fairlead Mount Plate or ATV Specific Mount is required to mount the fairlead to the winch.)
Product Description
PROMARK OFFROAD 1500 lb XT Series ATV Winch
Your work and play demands a rugged, durable ATV winch that won’t let you down when you need it most. With BEST IN CLASS horsepower and ALL METAL GEARS, these winches feature the power and performance to get you out of even the toughest situations. Your XT Series 1500 Winch comes loaded with 45 feet of aircraft-grade steel cable and a high output motor with thumb toggle free spool.
The XT 1500 Winch comes with our standard accessory package, which includes a handlebar-mounted thumb switch, roller fairlead, spring hook and pull strap, and all necessary wiring. The XT Series 1500 also features a Quick-Connect, color coded sealed contactor that takes the guesswork out of wiring.
Features:
  • Roller Fairlead
This sounds like a great winch for Sport Quads. If you have a big bore Utility you should upgrade to a 2,500lb or more winch. Even with a snatch block 1,500 is cutting it close for a full size Utility.
    • By Tim Keiper
