it is a 99 blaster just bought it tonight. The guy told me it has a brand new clutch in it. Ride rode it around for awhile now when you pull the clutch in it feels like there is nothing there and the clutch doesnt disengage. When you force it in it still goes so i dont think the clutch is out of it what could i do to fix this
Without knowing the history of it we are just guessing !! Have you checked the oil !! or pulled the cover off to see what up ?? OX probably has the owner manual you can down load !!
thanks guys i dotn think it is the clutch its self i am pretty sure it is some kind of adjustment because when it happened i rode it back home just had to force the trans to shift with no clutch so that would meen it isnt the clutch plates wouldnt just some kind of adjustment. Also the cable is not broke it does turn the spring loaded lever in the case of the motor just the clutch will not disengage
so you are able to powershift w/o the clutch, is that correct? Does the bike move forward when you give it gas when in gear with the clutch lever pulled in (which it should not) or does it not move (which it should not move)? :huh:
I found my problem the push rod is broke now for the new problem it is broke in the far end way over by the clutch i got a piece out that is maybe 2-2 1/2 inches long the rest is still in there. i have tipped the quad up on its side shook it the other piece will not fall out of there how do i get it to come out
    • By Coyote251
    • By KSIM
    • By KSIM
      View File 2018 CF-MOTO Z-Force CF1000US-2 service manual
      CF-MOTO Z-Force (CF1000US-2) (2018) service manual
      Submitter KSIM Submitted 03/19/2025 Category Other Brands UTV
