Seems my ATC went from a semi-working bike, to a project. Originally a traded for it, on the assumption it worked. Then, it didn't. Started with the carb, didn't really know what I was doing, and had to buy a new one. Lesson learned. Then took apart the top end, and it turns out the piston / rings and all that was near brand new! SCORE. So, I cleaned the rust out of the gas tank, and was gonna put it back together. This is where I am at now. Cleaning out the rust, I discovered 6 pinholes through which gas was leaking. The pictures show the stripping of the paint, the sanding of the metal, and the J-B weld plugging up the holes. More to follow! Painting it this week. Any thoughts / suggestions would be appreciated.
    • By Frank Angerano
    • By Tinkeringreg
    • By Dumass
    • By Trent Finnessey
    • By DPDISXR4Ti
      Thanks...
