k so i dont know if i have a rancher or a foreman all it says is 420 fourtrax fuel injection and its either an 09 or a 2010, but a little while ago the 4th gear sounds like it winding up something it shouldnt and it wont move, it will rev but not move. the 5th gear does it a littlw only when i rev it up alot but it doesnt do any difference, all the other gears work fine. this ATV has been running great for awhile but just suddenly started doing this as i was driving on a road.
you have hi and lo range on this bike... does it do it in both ranges?
another thing to check it is that most of the es machines have a shift shaft that sticks out for emergency shifting... if you shift it through the gears and it works fine, then its the shift motor thats bad
    • By DPDISXR4Ti
      Thanks...
    • By Sportsman500guy
    • By qcm413
      Hi,
      thank in advance
