On a cold start with the choke on full, the bike will start and run but only for a few seconds. Then she dies. I can use the throttle with or without the choke to keep it running but she won't run past a few seconds with the choke on alone. It will stay running after I play with the throttle for a few seconds. Just doesn't seem right. Any ideas???
What year and have you done any mods to it ?? How does it run when its warm ?
Runs perfect when it's warm. I have a new old stock yoshimura team suzuki pipe i just put on but it did it with the stock pipe too. Everything else is stock size ( Hot rod crank and bearings, new piston, rings and gaskets all stock size). I bought the bike as a project and what a project it turned out to be. The piston and ring must have just been done because the honing marks were still there in the cylinder. Same thing I was going to do before I checked the conrod small end. I used all new parts anyway. Checked the valves, all good, cleaned the carb. Runs great other than the choke thing and it starts first time all the time so far, I just have to use the throttle.
What year is it ?
    • By Tinkeringreg
    • By kaidella
    • By jhamrick75
    • By Mmessy83
      I recently purchased a complete lt230s for$50. It was missing the kick starter gears which I got off eBay for $18. I’m trying to install the gears which after reading different threads about having it timed. I have it all timed but now it acts like engine is seized up but I know it’s not. What could be going on??? Any insight would greatly be appreciated.
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
