Anyone ever deal with balistics batteries? They look like the ticket for me
I also use a schumacker trickle charger
Wow now thats a cool battery
8 Cell EVO 2
Dimensions: 112MM (L) x 60MM (W) x 103MM (H)
Positive Terminal Location: Left
Weight: 825 grams (1.81 lb)
Voltage (Charged): 13.6V
Amperage: 15 Pbeq A/H
Cold Cranking Amps: 275 CCA
Operating Environment: -18°C (0°F) to 60°C (140°F)
Typical Applications: 1000cc and under multi-cylinder motorcycles and 450cc singles.
8 Cell EVO2 (100-011) - $159.99
I been doing some research and I haven't been able to find too many reviews on using this battery on ATV's and Winching.
I swear by the Odyssey batteries.
I had one in a old standup jetski that lasted a good 10 years under unspeakable abuse. Full discharges, floodings, and full salt water shorts.
They also have near no internal discharge do they can be left alone without a battery maintainer for seasons on end and will still be ready to go when needed.
They are expensive, but so worth it.
8 Cell EVO 2
They might be a newe company but the specs on the batteries are awesome. an 8 cell battery weighs only 2lbs!
I hope this isn't considering a hijack of the thread.....
But someone mentioned using a trickle charge on the battery...
Is the necessary?
What qualifies for if it is necessary? The length between rides and/or the temperatures in the area?
Sent from my DROID X2 using Tapatalk
It all depends on the temperatures and parasitic draw. It's best to remove the battery and store it somewhere where it will be warm. Also lead acid batteries (wet cell) have internal draw that happens all the time, so they will discharge themselves and it gets worse with age.
It's a good idea to put them in the garage and on a tender every so often during winter. This also keeps the electronics in your quad from draining them. At the very least, disconnect the negitive terminal before leaving it be for long periods of time then charge it before you use it again.
    • By Sportsman500guy
    • By alain
      I just got this quad from my father in law need some tlc. Will need a new battery and does not know the battery PN as I don't have service manual. When my father in law had it , it uses lots of plugs, never got it service to verified why , he just buy an other plug and was good for a other 4 to 6 months .
      Any one would havd answers would be appreciated. Thanks
    • By waybel
      Picked up this old 2000 polaris sportsman 500 and the speedometer is dead .Tried the bypass to get the awd drive to work but no luck.I grounded the 2 brown wires going to the hubs .Didn't work.The AWD light does not come on and there is no power on the grey wires going to the hubs .I even tried connecting the 2 brown wires at the speedometer plug in .There is 12 volts on the red with white stripe connected to brown at the speedometer plug in .Does the speedometer need to be plugged back in for this to work.Could it be the switch or a burned AWD bulb ?
    • By bigbell
      Does any know what the stock jets are in the twin peaks?
      I bought the bike with a pipe on it and want to go back to stock setup.
    • By Jacksonbell
      I just went out to start my 2004 polaris sportsman 600 and nothing happened. It didnt have power to the dash and wouldn't turn over. I have no idea why, but it's not the battery because the winch still works. Can anyone help?
