By Tinkeringreg
By Mhatayas
By kaidella
By Shadow soul60
So I want to put LED headlights in my 99 Bayou 220. The stock headlights have some issue in the connector and they only work some of the time, so I want to replace them with LED light bars. I want to run them off the high beam switch. Which wire would this be?
By jwh
