I finally got around to installing my headlight bulbs among other atv chores. One head light bulb blew and the other came apart. I ordered 2 bulbs from ebay but the seller had mostly positive feedback. After my chores and lastly putting in the bulbs the left side is low
beam only and the right side is high beam only. What am I missing??
The bulbs appeared to have 2 filaments. I have the wiring diagram in front of me and it shows one wire for low and one wire for hi and then the two bulbs are wired in parallel. so if one is on low the other one is too and vice versa.
The quad is in the tow vehicle and isnt easy to move because I have no rims on it. When I put them on ill take the front plastic off. For now anyone have any idea??
Ebay Bulbs?
Wiring?
ground?
its hard 2 say... the bulbs are fairly cheap an i would try another set 2 see if thats the prob... an if it is then that an easy fix... if not then you will have to go through the steps of checking the light sockets with a test light an see what's up .. an then go from there an see what else ya can come up with..
They have one tab which makes em not sit perfectly flush. I might take that tab off. I dont have a factory bulb to compare the two. I do know the dealer charges 17 per bulb and i bought these for 1.50 each
You might be right maybe one is only touching the low beam terminal and the other is touching the highbeam terminal. When i get the tires back on i will take the front off and make sure everything is making contact.
I got my bulbs from the auto zone for my kawai and I still have both arms & legs so they didn't cost an arm & leg for them I think they were around 5 or 6 bucks for 2. Good luck with it.
    • By Panupong Pradchaphet
