By jwh
By Hagbard
Picked up a barn find that someone had already partially disassembled because the “motor locked up” but they never opened the case. Everything was bagged and labeled, and as I’ve mentioned before- I love a challenge ¯\_(ツ)_/¯
After a couple hours of fun with various pullers and hammers I managed to persuade the magneto/flywheel to come off. Hoo boy what a mess. Then I found an actual rats nest in the clutch cover. ಠ_ಠ
By olddude
Just wondering where you guy's an Gal's get your parts. I love buying OEM stuff but sometimes they just cost to darn much for what they are. I know, I know everybody needs to make a living but dang! $ 97.00 for brake pads on one side of the front of my KingQuad. There has got to be a better way.
