By jmeier1981
Ok guys Ive got a few more for ya.
TIRES:
Ive thought about getting new rubber for the wheeler it has some half worn down 25" Kenda executioners on it and Id like to get something that maybe rides a little better and does as good or better in the mud if thats an option. Any tire model suggestions? Also I would like to go to a 27" or mayb e even a 28" are there any disadvantages to doing this would I have to change anything on the wheeler to make up for the larger tires? Ive had a couple people tell me that they would be hard on the clutch.
WHEELS:
Ive seen some really nice looking aluminums but not sure they are tough enough to handle trail riding...Are they??? If so what would you reccommend, id like a little off set to give it a slightly wider stance and better stability but a buddy has a set of ITP wheels and the rear is offset a lot compared to the frnt and it looks great but hes constantly getting the back wheels hung up on trails
SNORKEL:
I see that the airbox on the brute is where a normal wheelers gas cap would be, so that being said am I good to go with water as long as it doesnt go over that point os is it not sealed up to the box? Also how about the belt and it staying dry, do I need to do anything to ensure that it doesnt get soaked and leave me stranded.
Oh by the way I love this thing the more I ride it the more Im glad I went with the powerhouse, Ive run with a couple polaris 500s 700s a grizzly 660, and 700 and a couple rincon 680s that were built and they cant touch my stock 750, although she likes her gas thats for sure i got about 50miles and Im needing a refill
By fishhouse3
This machine is ready to go and needs nothing - just hop in and hit the trails! I have over $20k invested in this machine. Priced VERY fair to sell quick at less than half that!!!
By Filthy_Mule777
I'm currently pulling my hair out over a customers 98 bayou 2x4 KLF300b. I've changed every electrical component on it twice and in a couple instances three times. Still no spark, I am baffled. Initially customer brought it to me complaining of a hard start no start situation and in fact, it wouldn't start. I changed the starter relay, spark plug, CDI box, and starter circuit relay after which it fired right up ran very well but then started having issues with the neutral switch/light where it wouldn't come on and wouldn't allow it start or even turn over. I found in the wiring harness a loose connection, I got it taken care of and secured and that solved the problem. So now that it would crank up again and run fine I called the customer over to test it out see what he thought as I've never heard it run before and I wanted to get his opinion on how it was running. Customer ride it around a little bit pulled it back on my carport and turned the key off and said it was great, and had never ran better or started so easily, then we set up a time for him to come pick it up the following day and he left. Well where he pulled it on my carport and shut it off was in the middle of the carport so I jumped back on it to park it off to the side, crank it up no problems put it in reverse went about maybe 18 inches and it stalled and ever since that point it has not had spark or run. I replaced the CDI box again with a better brand, I replaced the ignition coil twice put another starter relay on it and I've also changed out the stater and the pick up coil (pick up coil twice) and I'm just I'm lost I don't know what else to do to it. I've had this customers four wheeler for four months now whereas he's a patient guy I need to get it out of here so I can move on to something else. I've seen dozens of threads across different sites for off-road, 4 wheelers, ATVs, UTV's, whatever and they are all experiencing the same sort of issue but they never ever post hear the problem was or the fix. So I'm hoping somebody here has a little bit of knowledge on this particular issue sent since it seems to be so widespread. Thanks in advance for any help or suggestions.
By atvgenius
ATV Genius is the nations largest retail powersports distributor. What sets ATV Genius aside from others is we not only supply to dealers but we are also open to the general public. Wholesale ATV buys directly from the manufacturer, we cut out the middle man. Not only allowing us to save you money but allowing us to offer higher quality, longer warranties, and rare sought after vehicles.
We pride ourselves in our friendly, family like service & sales you will receive when coming into one of our stores. We also have higher experienced service techs that will not only be assembling your vehicles but servicing them as well.
Interested in becoming a dealer, or buying for yourself? Contact us today! Reduced prices!
www.atvgenius.com
