By DGBear
This thing is stuck in reverse! 2021 Axis with less than 15 hours on it. I cranked it, let it idle for a few minutes and when I put it in reverse the engine died and it won't come out of reverse gear. Any help is appreciated.
By joshua91673
first post
josh ohio
By Gwbarm
By Alleycat3677
Just bought a cheap moto4. Runs and rides great in low and high. Issue comes with trying reverse. Everything I read says foot brake on and in 1st gear. Then pull back into reverse. Nope. Not mine. I removed the safety wire on the brake because it wasn’t moving. Same issue without it. I put the quad into neutral and pulled hard and bam…..goes into reverse!! Then I stop and try to get into forwards and no luck. Stuck In reverse. Turn it off and try and the lever moves into low high and back down with ease. Start it up and same thing. Would really love some help with this one. Thanks in advance!
By Lafytafy
When my quad is shifted into reverse, the light on the speedometer doesn't come on. I've dug into the wiring and can't find anything other than it being a faulty switch. How do I get to this switch, is there a way to take it off without tearing it apart? I see that it may be accessible if I take off the air box but I am unsure of this. Thanks!
