cold proublems
By Trent Finnessey
So I’ve got a 2000 Honda 400ex absolutely love it!! I’ve had it for about a month, I ride with bruteforce 750’s, outlander 850’s and 1000 sxs’s and I was thinking of getting a trx450r carb and a full hmf exhaust. And probably doing the air box mod too, how much power would this give my 400? Just a little different or a big difference? Cuz if it’s not much of a different I’ll just stick with my dg slip on..... thanks!
By Admin
Looking for Arctic Cat ATV VIN (Vehicle Identification Number) Number Decoders? Once you find your ATV VIN number off the tag on your Arctic Cat ATV, you can go to all kinds of websites that have VIN Decoders available. The best ones are backed by the Arctic Cat ATV manufacturer, however there are plenty of aftermarket Arctic Cat ATV VIN Decoder websites on the web. This topic will stay pinned and if you find any to add, please do it with a reply.
CARFAX https://www.carfax.com
By gt_jacket
Hi,
I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in. Neutral and Reverse lights work.
All gears shift fine with no issues, has anyone seen this before? Just wondering if it is a bad sensor or something needs adjusting.
By Jacksonbell
I just went out to start my 2004 polaris sportsman 600 and nothing happened. It didnt have power to the dash and wouldn't turn over. I have no idea why, but it's not the battery because the winch still works. Can anyone help?
