New Dune Video
By QuadDad22
Picked up a 86’ LT 185 for $10 in trade value(my items only cost me $10)
recoil only , I pull the recoil and it won’t move , so I took it off , I can spin the crank there one full turn left then it locks up , and one full turn back to the right and it locks up
pulled the plug , the piston is moving up n down , both valves are moving(pulled the caps)
pulled the clutch off , oil pump gear , and it still locks up after one turn
any ideas or where to go from here would be greatly appreciated
im a 2 stroke guy so this all is new to me
thank you in advance y’all
By huntindog
TIA
By BenJammin
By DarkRider
