i hav a king quad 300 that was running fine. now when i start it, it takes longer to fire up then it runs ok for a few mins then when it warms it misses and backfires. it may choke out itself. it seems to want to run beter at low revs. the choke cable has broken but has bin broke for a wile and wos running ok with it broken before. any help would be great as we are expecting snow here and could do with the quad sorted. thanks. robbie
First off I would fix the cable. Pull the spark plug and see if it's in good condition, check your air filter make sure it's clean. If all checks out ok the carb might need to be cleaned.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Trent Finnessey
    • By Tinkeringreg
    • By beast6228
      However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it.  If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
      Adding to downloads library.
