2009 Can-Am Renegade 800R (New Hampshire)
By jwh
By PvtTarget
Will not go into 1st but if ya go past will go into maybe next gear. Will not shift into reverse. I have see others say that the shift cam assembly dowel worn or fall out. How do I get to this? Do I need to break case in half?
thanks for your help
By quadcrazy
QUADCRAZY NEEDS YOU!
By Hagbard
Picked up a barn find that someone had already partially disassembled because the “motor locked up” but they never opened the case. Everything was bagged and labeled, and as I’ve mentioned before- I love a challenge ¯\_(ツ)_/¯
After a couple hours of fun with various pullers and hammers I managed to persuade the magneto/flywheel to come off. Hoo boy what a mess. Then I found an actual rats nest in the clutch cover. ಠ_ಠ
By heath
