Hello I have an issue when the battery dies all the electrical componets start to fail.I removed the batery started it ran fine but nothing turned on no lights no cooling fan nothing.I though it can run without the battery.I think I have a alternator problem.:elvis:
Check all your body grounds first. Meaning take every ground off and clean them first. Check the tightness of the ground bolts. Once that is done then proceed with your troubleshooting. Guessing costs money so be 100% sure. D/L a shop manual and follow their test procedures.
Mario Welding Inc
Telecommunication
and Utility Equipment
Repairs
Mario Welding Inc
Telecommunication
Repairs
l
l
I hate when I post from my company phone and forget to turn off the signature
Thanks I'll give it a shot this weekend.Funny thing I couldn't make out what your avatar said till I clicked on it. Very funny me and the guys in the office were dying!
I have to agree, check all your grounds. Also check your voltage regulator and stator. What does it read at higher rpms? It's a 12V battery and should be reading 13V + i would think.
I read somewhere that there is a recall on some stators. What year is your quad?
If you can run it with out the battery then I would think that the problem is not your alternator, as the alternator is providing the voltage to provide spark. Did your gauge cluster die before this happened? (no speedometer, and Loss of 4 wheel drive) I know the units in the 2000's had an issue with water getting into the gauge cluster, and EVERYTHING runs through that damn thing.
    • By Thumpinhard25
    • By Tinkeringreg
    • By Dumass
    • By fwsamm
    • By kaidella
