I got the float in right this time. But it may need adjustment?
It still runs fast with no adjustment in the idle adjustment or in rich or lean.
Any suggestions on what to do now?
thanks
dennisg
1989 Suzuki Quadrunner.
I got the top end overhauled and putting it back together now.It ran good just smoked.Now it does almost the same thing. Excessive smoking and idling to fast with no adjustment on the screws. I am certain it is a carburetor problem but how to fix it is another problem.
dennisg
I have completed the carb rebuild and the engine runs and smokes just like before with no change except that it runs and starts better. It idles fast and cannot be changed by messing with the 2 screws on the carb. Why does it still smoke and why will it not adjust the idle?
dennisg
    • By Dumass
    • By Trent Finnessey
    • By DPDISXR4Ti
      Thanks...
    • By jhamrick75
    • By Ejwill
