Wouldnt start,pulled off the covers to check timing/set valves. cam sprocket bolt backed all the way out,keyway"tab"n sprocket broken off and cam chain laying in bottom,broken. Gotta split the cases to replace the chain,right ? It freinds bike,he wont be happy but,I guess he should'nt have let the kids mess with it !! Whatta ya think ?
1. Take the timing chain tensioner out.
2. Pull the cam cover off.
3. Remove the bolt from the cam and the cam gear
4. Remove the bolt that holds the side case and flywheel to the crank.
5. Pull the stator side case. Watch the little alignment tubes. Remember how the bolts came out, some are longer than others.
6. Pull the flywheel. Flywheel puller.
7. Take the chain off the timing gear on the crank,put on the new one. The easiest way to get it up to the top end is to drop a piece of wire down through the head and tie it on. Once you get the chain pulled up, tie to the frame to keep the chain from dropping back through.
8. Put the flywheel back on.
9. Put the side case back on,the magnet from the flywheel will grab the coil on the side case and the flywheel will jump out as you almost have the side case on,If everything is aligned properly to start with this won't be a problem and everything should slide back together.
10. Put the crank bolt back in and torque it. {Shop Manual for settings} 43ft\lbs??
11. Turn the flywheel over to get the timing mark in the window and reinstall the cam gear.
12. Check your timing marks.
13. Reinstall the cam bolt Torque it. {Shop Manual for settings} 43ft\lbs??
14. Reinstall the cam chain tensioner.
15. Check timing again, always wanna be certain!!
16. Put the cam cover back on.
17. Cross fingers
18. Start machine.....
Yeah, I got it. I was thinking of my old 750 4 banger where the chain dropped into the center of the case and turned 2 overhead cams. This is simple,except none of the stores here in town are open,plus I'll prolly have to order parts and wait,wait... Thanks Man !
      How to Choose the Right Cover
      Conclusion
      Covers the following models:
      1985   Scrambler Trail Boss
      1986   Scrambler
      1986   Trail Boss
      1986   Scrambler
      1986   Trail Boss
      1987   Trail Boss
      1987   Cyclone
      1987   Trail Boss 4x4
      1987   Trail Boss 4x4
      1987   Trail Boss 4x4
      1988   Trail Boss 2x4
      1988   Trail Boss 4x4
      1988   Trail Boss 250 RIES
      1989   Trail Boss
      1989   Trail Boss 2x4
      1989   Trail Boss 4x4
      1989   Big Boss 4x6
      1989   Big Boss 4x6
      1990   Trail Blazer
      1990   Trail Boss 250
      1990   Trail Boss 2x4
      1990   Trail Boss 2x4 350L
      1990   Trail Boss 4x4
      1990   Trail Boss 4x4 350L
      1990   Big Boss 4x6
      1991   Trail Blazer
      1991   Trail Boss 250
      1991   Trail Boss 2x4
      1991   Trail Boss 2x4 350L
      1991   Trail Boss 4x4
      1991   Trail Boss 4x4 350L
      1991   Big Boss 4x6
      1991   Big Boss 6x6
      1992   Trail Blazer
      1992   Trail Boss 250
      1992   Trail Boss 2x4
      1992   Trail Boss 2x4 350L
      1992   Trail Boss 4x4
      1992   Trail Boss 4x4 350L
      1992   Big Boss 4x6
      1992   Big Boss 6x6
      1993   2502x4
      1993   3502x4
      1993   2504x4
      1993   3504x4
      1993   Sportsman
      1993   2506x6
      1993   3506x6
      1993   Trail Boss
      1993   Trail Blazer
      1994   3002x4
      1994   4002x4
      1994   3004x4
      1994   4004x4
      1994   3006x6
      1994   4006x6
      1994   Trail Boss 2W
      1994   Trail Blazer 2W
      1994   Sportsman 4x4
      1994   Sport
      1995   3002x4
      1995   4002x4
      1995   3004x4
      1995   Xplorer4x4
      1995   4006x6
      1995   Trail Boss
      1995   Trail Blazer
      1995   Sportsman 4x4
      1995   Scrambler
      1995   Magnum 2x4
      1995   Magnum 4x4
      1995   Sport
    • By Brian Emerson
      Hi Guys, this Quadmaster has an extremely loud bang after turning key off (from idle), scares the stock, dog and missus, any ideas on what to check.
      Thanks and regards,
      Brian
