Guest Fox300exchic
There are 1,929,770,126,028,800 possible color combinations on a Rubik's Cube.
Gandhi once wrote an open letter to the British people urging them to surrender to the Nazis and to accept whatever fate Hitler had in store for them.
NASA countdowns start 43 hours before launch.
A recent survey of executives concluded that 91% consider a sense of humor important to career advancement.
The area code for Antartica is 672.
Forty-eight percent of Americans think aliens have visited Earth.
Elvis Presley made only one television commercial, for Southern Maid Doughnuts, in 1954.
The original Guinness Brewery in Dublin, Ireland has a 6,000-year lease.
Only 2% of Americans say they're in a good mood every day.
Ulysses S. Grant was once fined $20 for speeding. On his horse.
The hole in a ship's bow for a rope, like the ones used to secure an anchor, to pass through is called a "hawsehole."
New Jersey is the only state where all its counties are classified as metropolitan areas.
April is "National Humor Month."
In France, it's legal to marry a dead person.
Before 1900, boxing matches lasted all day and sometimes went as long as 100 rounds.
The "you are here" arrow on maps is called an "ideo locator."
According to the FDA, a cup of orange juice may contain 10 fruit fly eggs, but only two maggots.
On Venus, a day lasts 5,832 hours.
George Washington was deathly afraid of being buried alive.
Crayola is a French word that means "oily chalk."
  • 4 years later...
    • By drag_on
      after the gully wash i dont know if its such a good idea to go
    • By Banshee898
      2014 Honda Rancher TRX420TM1: Unit starts right up, once it warms up it stalls and more difficult to start but once it does start it won't stay running. I have replaced the fuel assembly, IACV, O2 sensor and fuel injector. There are no active DTC codes. Disconnecting fuel line at injector and turning on key there is a steady stream of fuel. Plug looks good did not see crack in ceramic. Is there any way to test the ignition coil?
      Thanks for any help.
    • By anthonyd256
      I have a 99 Yamaha bear tracker and I have converted the front brakes from drum to disc fairly easy but I cant figure out how to convert the rear with out hacking apart the rear arm. tried to use parts from a wolverine since the rear arms look similar but the caliper mount didn't line up on the bear tracker axle. Can anyone give me any clues or has anyone successfully converted the bear tracker rear brakes. I would even purchase a conversion kit if there is one. Any help on this would be greatly appreciated.
    • By RRP
      My new 2023 Polaris Sportsman 850 is in the shop for a pinched Wiring Harness from the factory...
      I did one ride on it (100kms), then to the shop for a month, waiting for them to replace it with a new one.
    • By dvs1961
