Trivia
By Banshee898
2014 Honda Rancher TRX420TM1: Unit starts right up, once it warms up it stalls and more difficult to start but once it does start it won't stay running. I have replaced the fuel assembly, IACV, O2 sensor and fuel injector. There are no active DTC codes. Disconnecting fuel line at injector and turning on key there is a steady stream of fuel. Plug looks good did not see crack in ceramic. Is there any way to test the ignition coil?
Thanks for any help.
By anthonyd256
By RRP
My new 2023 Polaris Sportsman 850 is in the shop for a pinched Wiring Harness from the factory...
I did one ride on it (100kms), then to the shop for a month, waiting for them to replace it with a new one.
By dvs1961
