have a 2000 quadmaster 500, my problem is the rectifier burned out, I replaced it now when you turn the key the neutral indicator and reverse indicator lights wont come on and wont start with the push button, I can turn key on and pull start it, and runs great, and will also light the indicator lights up but will be really dim, also the headlights will be dim to, also bought a new battery and still does it, i checked the fuses under the seat and all are good, any ideas on problem? Thanks
  • 3 years later...
    • By Trent Finnessey
    • By Tinkeringreg
    • By Randomnumber73
    • By kaidella
    • By jwh
