By Randomnumber73
I'm working on my uncles grizzly and it sparks once on initial cranking then no more after that. If I let off the start button then press the start button again it will spark once then stop sparking. I was wondering if anyone seen this issue before. Also I've never used forums before so sorry if this question is in the wrong location.
By P_syko
By TimothyLindblom
Timothy
By quadcrazy
Covers the following models:
1985 Scrambler Trail Boss
1986 Scrambler
1986 Trail Boss
1986 Scrambler
1986 Trail Boss
1987 Trail Boss
1987 Cyclone
1987 Trail Boss 4x4
1987 Trail Boss 4x4
1987 Trail Boss 4x4
1988 Trail Boss 2x4
1988 Trail Boss 4x4
1988 Trail Boss 250 RIES
1989 Trail Boss
1989 Trail Boss 2x4
1989 Trail Boss 4x4
1989 Big Boss 4x6
1989 Big Boss 4x6
1990 Trail Blazer
1990 Trail Boss 250
1990 Trail Boss 2x4
1990 Trail Boss 2x4 350L
1990 Trail Boss 4x4
1990 Trail Boss 4x4 350L
1990 Big Boss 4x6
1991 Trail Blazer
1991 Trail Boss 250
1991 Trail Boss 2x4
1991 Trail Boss 2x4 350L
1991 Trail Boss 4x4
1991 Trail Boss 4x4 350L
1991 Big Boss 4x6
1991 Big Boss 6x6
1992 Trail Blazer
1992 Trail Boss 250
1992 Trail Boss 2x4
1992 Trail Boss 2x4 350L
1992 Trail Boss 4x4
1992 Trail Boss 4x4 350L
1992 Big Boss 4x6
1992 Big Boss 6x6
1993 2502x4
1993 3502x4
1993 2504x4
1993 3504x4
1993 Sportsman
1993 2506x6
1993 3506x6
1993 Trail Boss
1993 Trail Blazer
1994 3002x4
1994 4002x4
1994 3004x4
1994 4004x4
1994 3006x6
1994 4006x6
1994 Trail Boss 2W
1994 Trail Blazer 2W
1994 Sportsman 4x4
1994 Sport
1995 3002x4
1995 4002x4
1995 3004x4
1995 Xplorer4x4
1995 4006x6
1995 Trail Boss
1995 Trail Blazer
1995 Sportsman 4x4
1995 Scrambler
1995 Magnum 2x4
1995 Magnum 4x4
1995 Sport
