Ok, I see idle issues here but none of them seem to fit my problem. My quad idles High when cold then is stalling when warm. ( High enough that I can't get it into gear.) Carb has been rebuilt, air filter is clean, Compression is good,it's fouling plugs like crazy and the choke seems to make very little difference. I've checked all the cables to the carb and it just doesn't make sense! It acts like a choke problem but everything checks out ok. I may try changing the supressor cap but damn, I'm getting tired of throwing money @ this thing. If I get it warmed up good it pops pretty bad during deceleration. Could a clogged muffler cause this? I've done everything I can think of on the intake side. Just wondering if anybody has run into issues with this style muffler/spark arrestor. All I can say right now is :aargh:
By pilot screw, do you mean the one for the idle circuit? I have tried to lean it out to Dangerous settings and it still runs rich as heck/ By Dangerous, I mean 3-4 turns open, and down to 1/8 turn closed. It doesn't seem to make any difference. I'm really thinking it is in the choke. I'm puzzled and ready to just buy a new carb......but I'm stubborn. Maybe I'm missing a screw somewhere> I walked away from it and waiting for better weather.
I'm pretty sure we are talking about the same screw, it is commonly called the idle circuit, pilot circuit or low speed circuit. It controls air/fuel mix at an idle and at initial throttle opening. There is a separate screw for idle adjustment, but it doesn't change the fuel mix, it just opens the throttle a bit. If you are still that rich even if you have the pilot screw that far in, then I would agree that you have a choke problem. Usually if turning the choke on or off has little to no affect, that means there is something wrong with the choke. Most motorcylce or ATV carbs do not use a true "choke" system which simply restricts airflow through the carb, hence the term "choke". Most of these carbs use what is called an "enrichener circuit" opening this circuit increases the amount of fuel that is available at an idle position without letting extra air in. It's affect is similar to richening the pilot circuit, but you don't have to make a permanent adjustment, switching the choke on and off is essentially richening or leaning out the pilot circuit instantly. If the enrichener is not blocking the circuit properly in the off position, it will act as if the "choke" is on even if the switch is turned off.
Another question, was this problem occuring before the carb was rebuilt, or did it start to occur afterwards. This sounds stupid, but I have seen it happen before. I had a friend who was having carb problems, so he took the carb apart, replaced some gaskets, cleaned it out, and put it back together. The machine would start and idle fine, but as soon as you touched the throttle, it would begin to run extremely rich, and would only clear up when you opened the throttle completely, and would backfire when you let the throttle off. He gave up and brought it to me, he said he wanted to check the vavles, so I did that first, they were fine. So I took the carb back apart to see if he put something together wrong or lost a part etc... As soon as I pulled the top of the carb apart, I noticed the problem immediately, he had put the jet needle in upside down. When the throttle was closed, the top of the needle was just long enough to keep the needle jet and main jet closed, but as soon as the throttle was cracked even just a bit, the needle and main jets were wide open. With this circuit wide open, fuel flows into the venturi at the rate needed to sustain a full throttle application, obviously this is going to make things way too rich. I flipped the needle back over put everything back together and it ran perfectly. My friend was pretty irritated with himself, he is pretty good with machines, but everyone has a brain fart from time to time. Just something to check.
You also asked if a clogged muffler could be your problem, I would guess that it isn't your problem, but I can't rule it out. It wouldn't hurt to make sure that things are clear. I do think that it is possible that a timing issue, or improperly adjusted vavles could be giving you problems. I would focus on the choke first, if it turns out not to be the problem, at least you will have ruled it out.
Thanks Josh. We are talking about the same idle air screw. With some time away from it and your help I'm gonna look over the entire choke set-up. I checked everything in the carb and it was all clean and open. I just ran it a bit tonite and the choke does NOTHING to change the way it runs. I'm gonna check to make sure the cable and hand control is actually working. This problem was happening before the carb rebuild but I only removed the cable then put it back on when I put the carb back on. I didn't check to see if the cable is pushing the plunger back down. I'll keep yah posted. I think I might have "thought" of the source. Thank you.
Someone also mentioned the fuel petcock could be bad sucking fuel into the vaccuum port causing a rich condition but that seems to hold vaccuum just fine.
The suggestion you got about the fuel valve leaking fuel into the intake vacuum is a good thought. You can test that by removing the vacuum line from the petcock, block the nipple on the petckock to keep it sealed, block the line so you don't have a vacuum leak and turn the peacock to the "prime" position to let fuel through. If the machine runs ok like this, then a bad peacock would appear to be the problem. Good luck.
My quadmaster did the same thing. what i had found is the slide choke plunger had a slight bit of wear on it. i noticed with a magnifiing glass. changed it and it was better. then i loosened off all of my cables and then set my idle screw after it was warm. once that was done and the quad was cleaned off i started the quad and set the throttle linkage idle screw to the proper speed. then i reset my cables. after that it worked like a top. If thats ok then i would look closley at your jets. my brother in law used a file on his and fubared them.
Your friendly neighbouhood mechanic.
I'll be damned!!! I looked over the cables and hand controls and found the choke cable adjuster was completely off the threads and the locknut was off the tube. It makes more sense now cause the cable was a pain in the butt to put back on the carb. The cable elbow is under the handgrip so I never noticed it had come loose. It explains why it would die when making tight turns as well. Once I put the cable back together and slacked the hell out of it the engine ran GREAT! Idles like a charm and once I re-adjust the choke cable i'm confident it will run like new. I feel like an idiot that such a simple fix caused that big of a problem. I changed the plug and ran it around for a while and I have to say this thing has NEVER run this good since I've owned it. The plug looked good after about 15 minutes of running it. Light brown, not BLACK and carboned up! Thank you all for your help.
Thanks again Josh. This thing runs so good I just cannot beleive it. I left it idle for over 15 mins and it never skipped a beat. The fan never even kicked on with the the temps in the upper 70's. I'm gonna have some fun with it this summer for sure!!
  • 4 months later...
:biggrin: Still running great and this thing pushes topsoil and gravel better than some small tractors. 50" blade and It pushes with no problem. Gotta use lo if it's really wet. ITP Mudlite radials and mud = FUN!!!!
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Dumass
    • By Trent Finnessey
