Ended up riding again today :yes:thought I`d share with with QC
This is Pikes Peak 14,000 ' In the summer you can drive up to the top
My buddys KTM rocket:yes:
Had a big BBQ after and cruised home Can`t wait for next Sun :yes:
I think its june 26 th If I go I will:yes: If not Jonny450r will because he racing in it
Thats correct Dale June 26 this year for pikes peak. As far as pictures go I'll do my best to get them cause when I am in race mode, I tend to forget about taking pics. Maybe my friend taking his renegade up pikes peak will remember to take pics during practice the week of.
Do you have a Go-pro helmet camcorder ? Wonder if Willypop is going ??
    • By wheeliewayne
      my  2012 big bear 400 is hard shifting  can anyone help me
    • By TimothyLindblom
      Timothy
