Im having some issues when putting it into gear( High specifically ) It doesn't seem to go in all the way and makes like a grinding noise and won't engage. I have to take back out and try again. Seems to happen if the engine rpm's are revving. Wondering if anyone else has had this issue or similar, and what I can do about it. I only have 200 miles and 26 hours on the machine just doesn't seem right. thanks
This happens alot when you rev above idle and try to change gears. Two common problems are if your idle is turned up too high from the winter riding season (carb) or if the autochoke/efi is still set to let the bike warm up.
I believe the 500 is still a carb model if so then adjust the RPM.
Adjusting Engine
RPM (Idle)
NOTE: The idle RPM is not adjustable on the EFI
models.
To properly adjust the idle RPM, a tachometer is necessary.
To adjust idle RPM, use the following procedure.
NOTE: The idle adjustment screw is located on
the right-hand side of the carburetor.
1. With the transmission in neutral, start the engine
and warm it up to normal operating temperature.
2. Turn the idle adjustment screw clockwise one turn
past the recommended RPM setting; then
The other thing would be to check that the pod reads the correct gear and not displaying an error.
Here is a link to the service manual:
http://www.quadcrazy.com/atvforum/arctic-cat-atv-forum/8558-need-service-manual-here-they.html
Edited by swampcat07
Added step by step for checking idle.
The 2005 auto carb has a extended throttle adjustment. It will look like a rubber hose about 4 inches long with a knob hanging off the back side of the carb.
Turning clockwise will increase rpm, Counter Clockwise will decrease rpm.
Why is it doing what is doing.
When the engine is at it's proper rpm the Centrifugal Clutch is fully disingauged and the is no ingaugement of the bikes drive system. As engine rpm increases the Centrifugal clutch starts ingauging the drive system, the belt starts rotating and the trans starts turning.
The transmission on these bike are a streight gear geartrain and the there are no synchronizers in the system. So with the rpm's raising everything in the trans is moving and your trying to a move a non-rotating gear into a rotating gear. With out a synchronizer the gears will never mesh.
Why has your engine rpm gone up? More than likely it is a varnish build up in the idle curcuit. The varnish has restricted the idle curcuit causing the engine to be running leaner at idle. The lean condition causes the engine to increase rpm.
I would recommend running a good fuel system cleaner in gas. It is also a good idea to run a good fuel stablizer designed to work with ethonal. Todays gas sucks.
  • 2 years later...
I have a 08 arctic cat 500 an mine did the same thing just took it and got it fixed what it was the teeth on the gear had broke off
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By neilroy87
