good deal !! Your gonna love it,, you will be impressed
i hope so lol....i should receive it friday no later than saturday.....does it hold only the thin ipods???
will do !
RZMask’s Green Solutions
Recycling has become more important than ever as it turns would-be waste into valuable resources. Recycling creates jobs, saves money, protects health of humans and wildlife and most importantly helps the environment. RZMask’s N99 active carbon filters are re-usable and hand washable, making for a long lasting, quality product. We also Support Blue Ribbon Coalition and Tread Lightly, to promote responsible and safe riding for everyone, everywhere.
Hey folks, they arent quite ready to go, however we are offering a 20% discount on the current inventory by using the coupon code "UTV20"
Breathe safe!
I`ll check out the web site !! thanks !!
  • 5 months later...
  • 6 months later...
  • 5 years later...
    • By mehim
      Hi everyone.
    • By p5200
      The studs in the sprocket hub are stripped out. The hub is probably walloed out also. Probably will have to have a new sprocket hub. I doubt I have the ability nor the tools needed for this job. Thanks for all suggestions/opinions!
      20240225_155255.mp4   20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4
    • By DaDolt
      So, I found myself in the only 5' deep water hole in Moab with the King Quad. Before I could get off it swallowed water at idle and died. The river water was not very clean. I pulled the plug and pumped the water out of it with the starter. I cranked on it and it popped for a second and then was done. Towed it back to the trailer. When I got home I checked the compression and it had none. I have a factory service manual. Disassembled and found the rings stuck in the piston lands. New rings and back together. I try to start it and get a C12 code CKP - crank position sensor. Troubleshoot and find it to be shorted. Installed aftermarket CKP, still get code. Check voltage on new CKP and only get 4.5V, manual calls for 5V minimum. Pulled every connector apart on vehicle and cleaned. Have continuity from CKP sensor side of connector to ECM harness. Install a known good ECM from another 2005 KQ I have. Vehicle fires and I let it run for 10 minutes. Shut it down and put the original ECM in and get a C12 code again and won't fire. Put the known good ECM back in and get C12 and no fire. Tested both ECM's in the other KQ and runs well on both ECM's. Installed a used stator and CKP. Still get a C12 code. Check used stator, 200 ohms and 6.5 V out of the CKP at the ECM harness. Checked ground at ECM harness and it is good. Checked spark with spark plug and without, none. Checked resistance and peak voltage on coil and it is in spec.
      This thing has me baffled. All of the electrical possibilities seem to check out. Might be far fetched, but could the rotor key have sheared when it shut down suddenly when the cylinder filled with water? I know rotary lawn mowers can shear the flywheel key when the blade stops suddenly from a rock or stump. If the key is sheared and the flywheel is out of time by a few degrees could this be giving the C12 code? The voltage output is correct but at the wrong crankshaft position (wrong time).
    • By jatho
      Does anyone know what year they stopped producing the King Quad 300? - particularly in Australia and New Zealand
      What were the design changes?
      Does anyone know of a safe paint stripper for ATV plastics other than Permatex, I can't seem to find that one in my area.
