just brought this home today. my son was riding it for a hour or so. he stoped to help me with move things around in the shed. it sat for 15 to 20 min. could not get it started.
put it on a charger for a hour and got it started by playing with the throtle. my son rode it
for a half hour went down a hill it backfired and killed didn't get it started. it seemed to start fine when cold.
thanks for the help
Dan
after posting this I whent out to take the charger off and I tryed it and it started.
This thing didn't get used much and the last owner said he last used it for deer hunting
I'm hopping it's bad gas. I put some sea foam in the tank.
Dan
If it is bad gas, it would be best to drain the tank, and maybe put some seafoam in with the fresh gas to try and help clean things out. I would say you need to clean out the carb, but your machine is fuel injected, so you may be having problems with the FI not wanting to work because you are having problems with the battery, the charging system, or bad connections. I would check all of your electrical connections and make sure they are secure and make sure the battery is full. If not, top it off with distilled water, and try giving it another charge and see if it helps. If your battery is not in top shape, the FI will not work. If you keep having to put it on a charger after that to get it to start, then you most likely need to replace the battery. Good luck.
thanks for the help
Dan
HELLO YOU WILL FIND THERE IS A RECALL ON THE ECM BOX UNDER THE SEAT . TAKE IT AND THE VIN TO THE DEALER HE SHOULD BE ABLE TO REPLACE FREE FROM SUZUKI .THIS COMPUTER WILL BE FOR A 750 CC BUT WILL WORK PERFECT. I HAD THE SAME PROBLEM LAST SOMER AND SUZUKI REPLACE NO CHARGE . YOU CAN INSTALL IT YOUR SELF JUST BE SHURE YOU UN PLUG THE battery UNTILL NEW ONE IS INSTALLED . GOOD LOCK AND TELL ME HOW YOU MAKE OUT BOBTHEBUILDER
EMAIL [email protected]
Called a dealer today and he suggested the battery. I asked about the recalls and just said steering and throttle seal and they had been done. I think the ecm has been replace with a
pro jet power commander 111 or 3. Is this the same part or is't this the ecm?
Back to the battery I did put a load tester on it and it came up week and the it tested 12.54.
Thanks for your help I have been out of this sense the day of my tri-z
Dan
Dan
you will find it is a defective cdi unit mine was and meny others i talked two had the same problem . see if you can try a friends cdi to check it out .
That sucks, if you are cabable and/or willing, you may want to do the engine rebuild yourself or maybe have a trusted friend do it. If you have the dealer fix it, there is no telling how much it could end up costing. Good luck with everything, I hope you can get it fixed without giving up your first born.
  • 4 months later...
i had the same thing happen to mine turned it off sit for 10 min tried to start again and it wouldnt fire, pulled the air filter and sprayed starter fluid in there if fired up but reved to the sky so i shut it off, i replaced the plug and gas, i can get it to fire after about 10 second of turning over but still revs really high like full throttle open, i dont know where to go from here, any suggestions?
yes its fuel injected, where do i go about starting, i have pulled the plastics off and have found the fuel pump, fuel tank and am about to take that off ive dislocated the gas line from the pump and it seems clean, should i pull the fuel line and follow it to the fuel rail and check the injectior? should i pull the fuel pump and look inside the canister? ive never had any type of problem like this and im trying to trouble shoot the issue by looking at forums any help would be appreciated.
where the air intake connects to the throttle body there was a gap where it must have vibrated off, i think it was reving high because computer thought it was getting tons of air thus giving it tons of gas and making it rev super high.... problem fixed though thanks
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By carkivey3
