i never seen a starter set up like this , use to work on car's but this looks crazy to me . my starter spins and makes a grinding noise, well not really a grind i cant describe it . ok pulled starter and it works fine, i took off side cover and it looks like it dosnt hit the other gear to turn over the engine. some guy told me a starter clutch ,what the heck is a starter clutch and how do i install 1
Edited by redneckyankee
ur starter clutch is bad,it is located on the left side of ur bike behind the side cover,u will also need a balancer puller to remove the fly wheel,it's not that hard to replace,go to thes site and it will tell u how to replace ur one way,as well as parts needed,i have done a couple of them,make sure u replace the 52 tooth gear...................L&A Designs One Way Yamaha Raptor 660 Starter Clutch
message me if u have any questions....good luck
One suggestion, do not use a conventional 2-3 jaw puller to remove your flywheel. There is a specific puller made for removing the flywheel on your machine, and they aren't too expensive. It screws into the flywheel and has a bolt on the inside that screws in and pushes your flywheel off. You can get away with using regular generic pullers sometimes, but I have personally seen flywheels ruined by using the wrong tool. I definately agree that it sounds like your starter clutch is the problem.
    • By Ejwill
    • By pastorjeep
    • By TimothyLindblom
      Hey all, I just picked up this Massimo UTV for $500. Got it home and replaced the starter solenoid which successfully got power to the starter. Starter spun but engine didn't turn over although the engine is not locked up. I thought it was a bad starter. Got a new starter put on today and it does the same thing. Pulled the clutch cover and saw the engine is trying to turn over but something is slipping and not letting it turn over. I figured it must be the gear on the engine that the starter turns. Where can I get that and can it be replaced without pulling the motor? And am I correct that that's the issue?
      Thanks!
      Short video attached below
