as everyone with a king quad knows you need to be in neutral to start. i want to know how to make the quad so it can start in gear (1st, 2nd....). is it as simple as creating a short on the switch??? i have done the diff-lock mod and its amazing. i am getting tired of when ever i switch off the quad in gear, i have to find the neutral again and that involves rocking the quad forward and backward for it to down shift.
thanks
it is not a safe option but you should be able to just bypass the park neutral safety switch. test the switch in the neutral position and test the ohms of resistance the remove the 2 wires out of the plug and put in a resistors to make up the ohms needed. By doing this it basically tells the unit that it is always in neutral. try that. let me know if it works.
Your friendly neighbourhood mechanic.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Tinkeringreg
    • By carkivey3
    • By kaidella
