    • By Sportsman500guy
    • By DZL1
      Thanks in advance.
    • By mga
      I get it, turn counterclockwise will decrease, turn clockwise will increase.  My question is what exactly am i increasing or decreasing? Is it clutch pressure? In many videos i've seen it's always "turn counterclockwise" until you feel resistance then back off. Why is it always to decrease?
      I'm just curious as to what exactly is going on when i turn that screw right or left. And, since there's no manual clutch to engage or disengage, what is going on inside?
      Reason why i'm asking is while going down a hill in 1st gear, it appears to pops out of gear, but no neutral light, and if i stop, it's in 1st gear still. BUT, (always a but) if the engine is warmed up, it stays in 1st gear. The hill is too steep to use any other gear, so 1st with the brakes is the only way to go down.
    • By lewisrssll
      View File How To Perform Compression Test
      How to perform compresion test
      Submitter lewisrssll Submitted 10/06/2024 Category Other ATV
    • By jmercer
      Wondering if 1997 klf400b has a decompression, I’m getting 90psi on gauge.
