6000 Members
  • 5 weeks later...
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By DarkRider
    • By joshua91673
      hi every one .anyone out there my issue is my kick start wont stay out  i have to have some one pull it out.  it pull out easy just wont stay out to kick it over .kicks over and starts no problem
      also does this quad have a ajust mint for the rear spring .it sags when i get on it .or is this normal . thanks guys for your time
      first post
      josh ohio
    • By huntindog
      TIA
