hello everybody
I recently picked up a artic cat 300 4x4 year is somewhere between 97-99 i dont know exactly, but i've been messing with this thing and finally got it to run. When it started it was back firing and poping back so i thought ok some trash in the carb lets clean it. After being cleaned started back runs great except i noticed the header being cherry red after riding it a few laps around the house. So i figured maybe its lean, but then it started with an electrical problem, someone has pulled the oem starter button off and put a start switch at the fender with the factory wires, the only way to keep it running now is to keep the key turned with the starter engaged for it to run. does anyone have any ideas or wiring diagram it would be helpful
The first thing that comes to my mind is this, your key switch is not making contact in the "on"position, so as soon as you let the key back from the start position, it dies. Test the continuity of the switch in the on position, and make sure all of the wires are secure and making contact on all ends. I have no diagram, nor do I know where you can find one aside from buying a service manual, but I can tell you that if you use a multi-meter to test continuity and trace the wires paying attention to their color and markings, you should be able to figure out which wire is responsible for what. Also, you can find which wires are supplied with power by simply testing them on the DC voltage setting. If you don't have a multimeter, you can get a decent cheap unit that will serve most of your needs at RadioShack for about $25 or $30.
The VIN is located in two places on this bike.
The first is a foil label located forward of the engine on the lower frame cross bar.
The second is a pin-prick stamping on the left rear frame rail just inside of the left rear tire.
    • By Tim Keiper
    • By carkivey3
    • By beast6228
      However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it.  If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
