2000 Honda TRX350FM Motor Interchange
By Tim Keiper
By kawasig
By Trent Finnessey
By Randomnumber73
I'm working on my uncles grizzly and it sparks once on initial cranking then no more after that. If I let off the start button then press the start button again it will spark once then stop sparking. I was wondering if anyone seen this issue before. Also I've never used forums before so sorry if this question is in the wrong location.
By waybel
Picked up this old 2000 polaris sportsman 500 and the speedometer is dead .Tried the bypass to get the awd drive to work but no luck.I grounded the 2 brown wires going to the hubs .Didn't work.The AWD light does not come on and there is no power on the grey wires going to the hubs .I even tried connecting the 2 brown wires at the speedometer plug in .There is 12 volts on the red with white stripe connected to brown at the speedometer plug in .Does the speedometer need to be plugged back in for this to work.Could it be the switch or a burned AWD bulb ?
