What could be the possible damage to my 160, if the gallery drain plug came out while running it? It still turns over(piston not froze). Thanks Bruce
Gallery drain plug? Do you mean the oil drain plug, that you use to drain oil from the motor or something else? If it ran without oil, the extent of the damage would depend on how long the motor was running without oil, and the only real way to asses the damage, would be to take the motor apart and inspect it visually. The first thing I would do is replace the plug, fill it with oil, and do a compression test. If the compression is low then you know there is a problem. If not, drain the oil into a clean container, and check for metal shavings in the oil. If the oil is clean, that is a good indication that the damage was minimal and you can re-use the oil.
    • By DPDISXR4Ti
      Thanks...
    • By jhamrick75
    • By Joeguy
      So i bought a chinese carb and in messing around still trying to get it to run right i figured id pull the spark plug to see if it was running rich, well it was definitely but also i have a nasty mark on the strap (i think thats what its called) that looks like the piston has been smacking it. I never actually pulled the plug because i had it running for a second on starter fluid when i first bought it and was just stupid and figured whatever was in there was good. The part number on it is DPR7EA, which is similar to what is called out for in the manual but i assume the little bit off that the code is means it must be a bit longer or something. Unless the plugs are made like this, but i can pretty easily see that metal has been pushed away from the area of impact. What are the odds that my piston is trashed now you think? It does still run just not well due to carb issues but thats a whole other problem.
      Actually i just took a second to google both plugs and it says the reach is the same its just different resistor values and gap size, so maybe the bigger gap is why its hitting. Either way the actual one for it is on the way and i hope it just didnt do to much damage. Wish i woulda just went over the whole thing like i normally do with this stuff.
    • By HoldenBoy
      Hi all,
    • By ethie
      Hi All
      not sure where to start
