ITS BACK!!!! THE ONE AND ONLY MUDFEST IS BACK.....
Core Promotions, the original Mudfest Staff and Mud Life Magazine are working together to bring back The One, The Only, Okeechobee MUDFEST!!
Feb 18th, 19th and 20th, are the dates for the event, so mark your calendars.
Mud Life Magazine is promoting the event and we will be releasing all ticket, VIP ticket,
times, info and date information in the coming weeks.
Visit the website at THEMUDFEST.COM
SEE YOU IN THE MUD!!
    • By qcm413
      Hi,
      thank in advance
    • By gbanker
    • By mga
      I get it, turn counterclockwise will decrease, turn clockwise will increase.  My question is what exactly am i increasing or decreasing? Is it clutch pressure? In many videos i've seen it's always "turn counterclockwise" until you feel resistance then back off. Why is it always to decrease?
      I'm just curious as to what exactly is going on when i turn that screw right or left. And, since there's no manual clutch to engage or disengage, what is going on inside?
      Reason why i'm asking is while going down a hill in 1st gear, it appears to pops out of gear, but no neutral light, and if i stop, it's in 1st gear still. BUT, (always a but) if the engine is warmed up, it stays in 1st gear. The hill is too steep to use any other gear, so 1st with the brakes is the only way to go down.
    • By mattgoodwin
      I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
