just thought id ask if anyone has figured out how to bypass the reverse override completely in other words figured out to make it so you dont have to push and hold the "yellow button" at all. id like full reverse power in 2wd and 4wd. anyone figured it out?
Check out this link: Nyroc's ATV info website
This modification has been tested and works. I think if you decide to do this mod you should install a small waterproof switch so it can be returned to stock configuration. I personally do not want to defeat the limiter as I have riders of various skill levels riding my bike. But I understand the desire to defeat the reverse limiter. With that said.
Here are the wires to jump on a 2007 AC700EFI(Suzuki engine). Just a simple jumper from wire to wire. Fully seal all connections whether butt connector or solder(preferred). Do not ground or disconnect any wire.
On the ECU Module; it is the Gry/Blu wire, (grey with blue tracer) in the 8th position from the right. See the pictures and enlarge to see the numbers.
On the 2WD relay(outside); it is the Wht/Vlt wire, (white with violet tracer) on terminal #85. If you will pull the plastic rivet and lift the relay, looking at the bottom you will see that it is numbered.
Basically you are telling the ECU that you are in a forward gear when in reverse. There is no notice to the ECU that you are in reverse that I can find, only notice to the ECU that you are not in a forward gear when in reverse. That does eliminate the reverse rev limiter. As far as I can tell all other limiters will be operational and the indications on the POD should be ok.
It has been found that the wire colors are different from year to year and maybe even during the model year run.
The blue tracer on the grey wire is on the bottom in the picture.
ETA; Before doing any wiring changes on your quad, or anything, disconnect your battery.
* Edited thread title, included full atv info and issue.
    • By waybel
      Picked up this old 2000 polaris sportsman 500 and the speedometer is dead .Tried the bypass to get the awd drive to work but no luck.I grounded the 2 brown wires going to the hubs .Didn't work.The AWD light does not come on and there is no power on the grey wires going to the hubs .I even tried connecting the 2 brown wires at the speedometer plug in .There is 12 volts on the red with white stripe connected to brown at the speedometer plug in .Does the speedometer need to be plugged back in for this to work.Could it be the switch or a burned AWD bulb ?
