I got a 1986 suzuki 230lts it has been sputtering and spiting when you add a a little throttle so i took apart the crab to look for crap, i found not a speck of dirt. BUT i found that the pilot screw was messing a few parts, the washer and the o-ring. would that cause it to sputter when a little throttle is applied, it almost feels like the breaks are dragging when you give it a little throttle. thanks for any imput!
I would replace the missing parts and make sure all of the passages and jets are clear. I would also drain out any old gas and start with fresh fuel if you haven't already. I would also check for air leaks, make sure your air filter is clean, and make sure you have good spark. Get a repair manual, you will most likely need it.
    • By Mhatayas
      Adding to downloads library.
    • By mmikesell
    • By opnea
      Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
