I own a 1994 Timberwolf 250 and use it around the farm, I use it a few times a week if the weather is OK. The other day I went to park it and put it in neutral and when it got there the green light went out. I know it is in neutral because I can push it where I need to, and the battery is good because the lights work fine, but when I hit the starter I get nothing. Any help or suggestions would be appreciated.
Greg
if it is stuck in between gears it would only roll for a few feet then the synchro would pop it into a gear. does all of your other lights work. if they do you could bypass the neutral switch or replace the switch. this is the most likely cause. but i would definately start with the power and ground area first. if that is ok then i would look @ the switch.
your friendly neighbourhood mechanic
    • By Mhatayas
    • By jwh
    • By mans
      Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
    • By alain
      I just got this quad from my father in law need some tlc. Will need a new battery and does not know the battery PN as I don't have service manual. When my father in law had it , it uses lots of plugs, never got it service to verified why , he just buy an other plug and was good for a other 4 to 6 months .
      Any one would havd answers would be appreciated. Thanks
