Blue Fully Automatic Kazuma Meerkat 50cc
Negative Points:
-Rear mud gaurd plastic has been smashed on one side and also been spray painted black,
-Rear left tyre has a puncture
-The nut that holds the rear left wheel onto the axle is missing.
-Front Headlight doesn't work not sure whether the bulb just needs replacing or not.
apart from those negative points everything else is working fine.
how much could i expect to sell this for??
    • By carkivey3
    • By qcm413
      Hi,
      thank in advance
    • By Randel1
    • By geezer99
      I have an Axis 500 made by Hisun.  I uses a solid rear gearbox with no differential action.
      I would like to convert this to a true differential with locking ability.  I've searched all over trying to find a source with no luck.
      Has anyone done this before, or know of a source?
      Thanks,  Tom
    • By heath
