Hi I have a 2006 yamaha 350 bruin which has broken its timing chain the problem I have is that I cannot find the timing marks for the engine for tdc and 10degrees before tdc for the timingI have a manual for a 350 big bear but the marks must be different can anyone help thanks John
There should be a clear mark on the flywheel indicating TDC, it is usually marked by a "T". There should be marks on the cam sprocket somewhere that probably line up with an arrow mark on the head somewhere. This is just a guess on my part, I think the best thing to do is get a manual specific to your machine. If you are going to be working on it, you will likely need it in the future anyway. Hopefully someone who knows a bit more about these machines can chime in and offer more help, until then, good luck.
    • By Thumpinhard25
    • By leecon
    • By KSIM
    • By KSIM
      View File CFMOTO CF500-6 CF625-3 (CF600-3) CF625-6 (CF600-6) service manual
      CF-MOTO cf625-3 и cf625-6-cf600-6 service manual
      Submitter KSIM Submitted 03/19/2025 Category Other Brands UTV
