After riding my new (to me) 2000 trail boss, I noticed the fan NEVER ran, even after letting the quad idle for 15 minutes. I thought I had a problem with my fan or my thermister, so I did some checking and found both were working as they were designed...turning on at 260 degrees F. A further check on the various forums found that others noticed their fans not turning on.
I believe that this is a design error. The thermister, sitting on the downstream side of the radiator, is waiting for the oil to literaly cook before turning on the fan. I mean, if the oil has reached 260 degrees after going through the radiator, how hot is it in my engine? My belief is that the best oil temps are just above boiling (215 to 245 degrees F or so), so as to help eliminate any water build up, but keeps the oil from cooking.
I also noticed that the fan blows air through the radiator, then across the cooling fins of the head/jug. I feel it would be nice if the fan would come on at lower temps, to help with cylinder cooling as well.
So I came up with a mod that has really seemed to do the trick. Basically, I just placed at 10K ohm resister across the the thermister wires, so that it is wired in parallel (from one wire to the other). The result:
Before: Fan would only turn on at 260 degrees F, off at 240 F. Engine temp light activates at 290 degrees F.
After: Fan turns on at 245 degrees F, off at 225. Engine temp light activates at (estimated) 285 degrees F.
After making the mod, I tested it, and after idling for 10 minutes, my fan turned on!!!!
Oh, and when I placed the resister jumper, I was able to keep everything water tight. I pulled the pins out of the harness that attaches to the thermister wires. Once the pins were out, I used a needle to poke a small hole through each of the two "sealing bushings" that were attached to the wires. I then threaded the resister leads through these small holes, and soldered them to the back ends of the pins. Then I put the pins back into the harness, and for good measure covered the back of the sealing bushings with silicone, also covering the resister in the process.
If the temp figures are not low enough for ya, you could use a lower value resister. Go with a 5.6 K, and your fan would turn on at approximately 230 degrees, off at around 200.
If you already have a soldering gun, solder, and silicone, the mod only costs .99c for the resister!
This mod was done on a 2000 Trail boss. I'm sure it would work for other years and/or models. Check your owners supplement...if your thermister activates your fan at 260 degrees with 2519 ohms across, then it will work.
Edited by tawood
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Trent Finnessey
    • By Randomnumber73
