Sounds like the solenoid is sticking, it could either be the solenoid itself, the starter relay or the start button. You can test the solenoid by disconnecting power wire from the starter and hitting the start button, when you let go, check for voltage on the low current solenoid feed wire that feeds the start signal to the solenoid. If you get no voltage on that pole, test for voltage at the end of the starter wire where it would normally be connected to the starter. If the wire is still hot, then the solenoid is bad. If there is still power at the solenoid feed wire after you let the start button go, then it is either the relay or the start button. Next you need to find the relay if there is one, test that, and lastly test the wires coming out of the start button, see if they have continuity still after you let the button off.
    • By Tinkeringreg
    • By fwsamm
