I have a1992 polaris trailboss 350l that after I run the machine for awhile It will not idle, but when I let it sit it starts right up and idles. When I start it up first thing for the day it starts right up and idles it quits ideling when it gets warm any ideas or thoughts would be great.
If I turn the idle up then it will run to fast when I shift into gear it will grind. I thought about the pilot screw. is there a safety on this when it geets warm it shuts down because I do not hear the fan run much if at all? I know there is a part on the engine that heats up and then turns the fan on I was thinking about bypassing this and have the fan run all the time but wasent sure if this was not working if this would have this effect.
If it runs, but won't idle when it is warm, it wouldn't be because of any thermal shutdown protection. If there was a thermal shutdown, the machine would not run at all. I would first try adjusting the pilot screw and see if it helps. Does the machine run ok other than not idling when warm?
    • By Gunny
      Hope you enjoy the video ....
    • By Frank Angerano
    • By Tinkeringreg
    • By oxidized_black
