My brother wrecked my 07 vinson 500 yesterday tore up the front suspension pretty good, rim cracked tire slashed, tie rod bent into a u shape, and the front suspension pushed back about 2-3 inches towards the back of the atv. Im trying to find parts cheap as possible does anybody know if parts off a 02 vinson 500 will fit my 07? its the front right that has the damage, i found on ebay the front upper and lower arms with bearing for $60 if they will fit mine it would be great... also does anybody know where i can find a possible used rim and tire and tie rod, everything i find is super expensive, i searched ebay they only have like racing tie rods
Edited by Tazman6789
The arms have different part #'s, but are similar in design. The shock part #'s are also different. The only thing that is the same is the a-arm bushings. They may fit, the differences may be little to none, but the part #'s are different. I am also inclined to agree with Stoopidbot, check your frame for damage, if it is messed up, it won't be as simple as just bolting new parts on. I have first hand experience with that one. I messed up an a-arm and had to re-fabricate the mounts to just to compensate for the slightest frame damage.
frame is def bent a lil bit. its rideable the way it is tried attaching tow strap to control arm and other side to tree and backing quickly, did a bunch of nothing. lesson learned dont let anybody touch your atv but you.
Wow, that sucks, it looks like the frame is just as much if not more damaged than the a-arms. I can't even tell if the a-arms are damaged at all from the pic, I can tell that the quad is messed up though. What are your plans? The frame will be very hard to straighten, you probably need to replace it to fix it, and that is alot of work, but still cheaper than a new ATV.
i already replaced the a arms i though thats where they were damaged cause the paint was freshly chipped off a few welds on the arms, those are the new arms in the picture. for now im going to ride it as is until i can get my hands on a friends welder and see what kind of magic we can work, im thinking about cutting out the one cross support or both, hammering it back out and welding the crosses back in. we shall see. def sucks its an 07 but i bought it brand new off the dealer floor end of 09 only has like 300 miles on it
im thinking cut on the red push the yellow out a couple inches and weld the red back together probably take some heavy sheet metal wrap around both braces for extra hold power what do you guys think? any better ideas?
I think that the frame is already bent in the direction that you are thinking of pushing it. I think both sides need to be pushed back the other way, the left (damaged) side more so. I also think that there is more than just the frame rails that need fixing, the a-arm mounts themselves don't seem to be in the right place anymore. That could be from the frame being twisted as well as bent, or the mounts themseslves have been bent. I think the best thing to do would be to remove as much as you can from the frame, suspension and the front diff, and get a real good look at how it was damaged. I am willing to bet there is more damage than what you can see now. That thing is bent pretty good, especially considering that you have already replaced the a-arms, so they are straight, that is all frame distortion there. As far as riding the thing like that, I wouldn't go fast enough to hurt yourself if you crash, there could be cracked welds you don't see, and I am sure that allignment will make for a pretty scary ride at higher speeds. Also, how are your tie rods and the rest of the steering parts?
tie rod was bent into a u shape but that was replaced already also, the point of impact was the right tire the one thats pushed down it looks like the lower a arm mount in the pic is pushed in and the top is pushed out, the handlebars are just a lil off when im driving straight they are pointing to the left about an inch its pretty well jacked up and my brother is beginning to be a jerk about it when i told him the frame is $900 not including the week i would have to put into crossing parts over
the gap between the wheel well and tire is 2 inches on the damage side, 4 inches on the other
and the yellow arrow is the direction i want to push it back out to bring that lower arm mount out and bringing the tire up
I think I understand what you are saying better now, at first I was picturing the frame just being bent in that direction. Now I realize that you mean to move the whole thing straight to the left, maybe pushing the lower side out more and keeping the very top front end of the frame more or less where it is. While I get the concept, I would still take everything out of the front end and try to determine where the twists and bends are in the frame and try to correct them. If you have to, cut the a-arm mount off and move it back around to where it is supposed to be. I think that just pushing that side out is going to fix one problem, but lead to others.
well she survived the weekend, took it easy on her at first but by the end of the weekend she got her normal wear and beating, performed like a champ just like it always has. only complaint is that the front end is pulling slightly to the left but cant expect perfection until i get the frame taken care of. so now i have to get the rim repaired permanently instead of just the tube i threw in it for the weekend, and have to figure out a plan of attack for this frame
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
