Ive been looking around and reading alot about these clutch kits. There seems to be many out there and many different types. I do mostly trail riding and mud bogging. But alot more trail riding and some road riding. I would like a kit that gives me more lower torque and basically alot more power. Pretty much want the best kit for power. I run stock tires and i have no added mods to the bike, its all stock. I would like some advice on which kits you would recommand and which sites would you use and also what other mods would you added for better performance. I really dont want to mess with the computer much or add mods that will basically destroy the quad in no time. Runs and drives great now so i dont want that to change but if there performance parts out there that make the bike better i would like to look at them. So if anyone has mods done to there quad that they liked and they noticed added performance let me know.
A new clutch kit is not going to add power, it will only change the transfer efficiency and the way that the power is supplied. If you want a hard launch, you can use a clutch with a higher stall setting so the clutch does not engage until you reach higher rpms. Some clutches are designed for use with taller tires and will have an overall lower effective gear ratio, so you will have a lower top speed with stock size tires. Some clutches can slightly improve accelleration, decreases slippage, therefore reducing friction heat and increased backshifting. Moose, EPI and Dalton all make aftermarket clutch kits for your machine. There are some kits are designed for use with stock to 27" or 28" tires. These particular kits work well within that range only sacrificing a tiny bit of top speed with stock tires, but accelleration will be improved. They are intended to work best with a 27" or 28" tire, but work still work well with stock tires.
    • By qcm413
      Hi,
      thank in advance
    • By Ejwill
      Just aquired this Honda 4514. I had heard of them and seen them but had never really looked at one. Amazing machine from the 90s.
      It has a 14 HP inline 2 cylinder engine. A cute little fan like the old school cars had and a little radiator. It has a timing belt on the back of the engine running the cam and a water pump. Just like a miniature car engine with  electronic clutches to turn blades on and off. Pretty hight tech for the 90s not a small thing and built like a tank weighs in at 600 pds hydrostatic trans. I have found out that almost anything you have to do to it the engine has to come out starter timing belt water pump. Very expensive parts i think most got junked for that reason, i did find out they were built by John Deere except for the honda engine.
      Does anyone here have any expierience with these.
