When i start my bike the fuel is marking full and the gas tank is full and if i let it at idle it stays the same but when i go ride it within 2 mins it goes to empty and is starving for gas but stays running . Any thoughts ?
The fuel sender is fouled. I had the same problem on mine. Would be full then when i rode it would drop to empty. Techron can help the problem, I just ended up replacing the sender as it was just not accurate.
Mike
    • By Tinkeringreg
    • By DPDISXR4Ti
      Thanks...
    • By kaidella
    • By jhamrick75
