The battery is kept charge by electrical output from the stator, that current is then run through a regulator/rectifier unit that turns the AC current into 12 volt DC current. If the stator is not putting out a charge, then the machine won't run, if the regulator/rectifier is not working properly, it may start, but will likely die when the machine tries to switch to the secondary ignition system. Also, I believe that some machines won't run without a battery, I am not exactly sure why though.
Thanks DirtDemon, I really thought it could be started without a battery, however i have learned that the rectifier if still working needs to shed its voltage or it will burn up, therefore you still need a battery even if the battery is no good.
Do you agree?
Thanks Pineknot
    • By Panupong Pradchaphet
