By Tim Keiper
By mga
on my left brake handle (for the rear brakes) there's two wires attached to it. What are these wires for? They can't be for the tail light, since it only has on filament I tried to trace them, but i got lost in the harness. I checked wiring schematics, but didn't see anything like that.
I'll post a pic later.
By mga
2000 Big Bear 4x4 400.
do the front and rear drive shafts have to be lubricated? they have boots on them and i was wondering if i had to pull the boots off and grease the "U" joints? These are the ones close to the engine front and rear.
By mga
My 2000 big bear 400 4x4 has 26x10x12 tires in front and 26x12x12 in the rears. Trying to find replacement tires those sizes are hard to find, or, when i do, they cost a lot more than i want to spend.
But, there's a lot of 25" tires out there the same size, just 25" and not 26". If i got the 25" it should not make a difference....right?
By n4cer26
Hi guys!
I recently acquired a 2004 Sportsman 600 4x4. It originally ran great but now It runs very rough and only with choke on. It dies when you hit the throttle. I will be removing the carb for a good cleaning. At this point I'm thinking it's a fuel issue. I replaced the fuel pump and fuel filter today as they are cheap. When I get the carb back we will see how it goes. If it still runs bad I might try bypassing the fuel pump and running direct from tank to carb. Any ideas as to what I should be trying would be greatly appreciated.
Also, the carb has two nipples in the front in the front on each side. The left side has a vent hose on it but the right side is capped off. Shouldn't this one be venting as well? See pic.
I did pick up a new aftermarket carb to have just in case. There is a hose fitting on the right rear that my OEM carb doesn't have. What would this be for? I would think just keep that on capped? (See pic)
Thanksnin advance.
