That is a nice clean Blazer you got there. I too have an S-10 Blazer sitting on 33's, it's older and looks a little rough, but it gets the job done. It has a solid axle conversion, a narrow track Jeep Wagoneer donated a Dana 44 front and AMC model 20 rear. I plan to put a small block in it soon, just looking for a tranny.
Nice, looks tough, i just picked up a 96 blazer and i am currently swapping in a 68 327 with a tunnel ram and 1150 dominator carb, and a th-350 trans, the rear axle is getting swapped out from the 7.5 to the 8.5 limited slip. i am planning on dropping it a couple inches and adding ground effects making it a street ride.
you know i wonder bout that myself. the 97 4drs got old type front clip my 96 however has the newer style headlights and grille. i have seen other 97 4drs with the same old 95 style too. i have no idea why they made them like that. the 97 zr 2 door has the new style yet the 4 door dont. its just wierd. btw i have different bumpers on it that are more prerunner style and look better, ill update pics soon. and get some of the v-8 project goin on
    • By Winnem
      Hello.
      I've bought myself a Iron Baltic electric hydraulic plow lifter for my TGB, with a matching mounting kit. It was supposed to fit directly on my ATV. But I'm really not happy with the result. Had to cut off some of the cover under the atv, and still the angle didn't seem to be right in order to fasten the adapter on top. Also it touches the bumper and makes ugly marks.
      Is there anyone here with experience, or know a good solution on this?
    • By Saskatchewaner
      Anybody build/buy a lift table for working on your machines? I've got one of those little hydraulic motorcycle lifts but it just seems so tippy with a quad on it. And using jack stands with it means you're locked into a height.
    • By dvs1961
    • By gatorschevy
      just picked this one up and was wondering how you know for sure the the 2-stroke oil is going into the motor? I don't want to blow this thing up; I know I can unhook up the parts and just mix it myself but that's another can sitting around
    • By Earthmover
      Hi I'm thinking of installing a body lift kit on my 02 F-250. Can any one tell me if there is any hidden costs involved for instance, do I need to extend my brake lines, steering collum transmission linkages or wiring
